SailNet Community - View Single Post - Generator noise/vibration
post #2 of Old 03-16-2006
camaraderie
moderate?
camaraderie's Avatar
Cutting holes in the "box" can only help the vibration so I think that is the place to start. If that fails to reduce the vibration enough, then you might think about re-mounting the generator to the box with some joists through bolted to your box with some rubber between the two to dampen out the vibes.
camaraderie is offline
