SailNet Community - View Single Post - Just temporary, but it should hold
post #2 of Old 01-10-2010
scottyt
it looks as thou the boat was set up for roll reefing on the main. if this is true and you dont use it you could put 2 or 3 bails thru the boom to attach the main sheet to. you might be able to get away with one but i would use 2 and put seperate pulleys on each in case one lets go and to spread the load out some. then you could do away with the swivel on the end of the boom
scottyt is offline
