SailNet Community - View Single Post - Cal - Reputation of Quality
post #16 of Old 01-12-2010
Waltthesalt
I too have a Cal 29..'74. I'd assess the quality as mid-grade quality for the time. How the boat's been maintained and upgraded may be a bigger factor along with your preferences. I've done a lot of upgrading and that's easy to do on the Cal. In this market you should be able to get a well maintained boat upgraded with what you want at a reasonable price. Three things warrant special attention. Check for hull blistering, the fix is eapensive and time consuming. When I got my Cal 20 years ago I got one that has been peeled and epoxied. Check for deck water intrusion, that is fittings that have alllowed water to get into the deck's core. Sometimes you have to take a fastener out to see if water's inside. The fix is costly and painful. Finally the engine. Ideally you'd want a boat that's been repowered. Again a costly job
Waltthesalt is offline
