Old 01-15-2010
ssneade's Avatar
ssneade ssneade is offline
Somewhat Flexible Member
ssneade will become famous soon enough
Originally Posted by weephee View Post
Thanks Jim. This is good information. Do I need to remove the shaft in order to remove the cutlass bearing and can you tell me where you got the new bearing. Thanks again.
ya don't necessarily have to remove the shaft, but the props gotta go. once that's done you should be able to remove the bearing housing. the bearing sleeve is pressed into this. at this point check the shaft where it works in the bearing for wear. if badly worn, more than a one thirty second of an inch step, then you should replace the shaft also........
Self Proclaimed Genius
