SailNet Community - View Single Post - Epoxy Barrier Coat over Gel Coat?
post #3 of Old 01-17-2010
sailingdog
If the laminate is wet, then you will probably have to remove the gelcoat. However, depending on where you're keeping the boat and how wet the hull is, you may not need to peel the gelcoat, especially considering how long it is going to be out of the water.
If you have a moisture meter, it would give you a good starting point to judge whether peeling is going t be necessary. MaineSail has a great post on Moisture Meters and how to use them.
Originally Posted by lizardheadone View Post
I have read that in order for an older hull to dry out sufficiently you must remove the gel coat and let it dry out before applying an epoxy barrier coat and that it will not dry out without removing the gel coat. I also read of people putting an epoxy barrier coat over the gel coat. My questions are: Do you have to remove the gel coat in order for a wet hull to dry out? Is it acceptable to place an epoxy barrier coat over a dry hull? In my case my HR 35 is under a shed and will be there for 4-5 years during it's restoration. The hull has moisture. Will it be sufficiently dry after 4-5 years without removing the gel coat? Anybody with THE ANSWER? Thanks.
sailingdog is offline
