I was wondering if anyone could identify the possible problem I am having based of the symptoms I describe for my electric
windlass on my Morgan 323.
I bought the boat over 2 years ago and the first season and 1st half of the 2nd season the
windlass worked flawlessly. It is Lofrans Project 1500 vertical with controls both on the bow and in the cockpit. It was expertly installed by the previous owner using heavy gauge insulated wire and a separate breaker switch near the main battery bank.
As I stated the the
windlass worked flawlessly pulling up the part chain, part nylon
anchor rode and I always used it to pull up the slack as we motored forward rather than as the muscle.
So 2nd half of last season the
windlass would just randomly stop. Sometime it would happen half way through me pulling the
rode in - other times it would work dropping the hook but then not work at all when I would hit the button to pull it back in. Luckily it has a notch for a
winch handle on top that I was able to use it as a manual windlass to get the
anchor up...sometimes if I kept pushing the windlass retrieve button while winching it up manually it would randomly start working again. Sometimes it would work the entire time - others not at all and others half and half.
I always made sure the engine was on and revved up while using the windlass and I have 4 Group 27 Gel Cells that were always more than 75% topped off before using the windlass. I checked all connections, disconnected them cleaned them and reconnected them but they looked perfect in the first place.
So I have no clue what is causing this problem. Has anyone heard of anything like this or have any ideas?
Thanks so much in advance
