SailNet Community - View Single Post - SSB Backstay antenna
post #15 of Old 01-27-2010
k1vsk
Originally Posted by Zanshin View Post
K1VSK - what sort of interactions are you referring to? If I were to embed an antenna into the nonconductive Dyneema, could you envision that the structural integrity might suffer over time? Dyeema doesn't like temperatures of over 150C, could those be reached somehow when transmitting?
The most common form of interaction is parasitic and takes the form of effectively changing both the impedance and electrical wavelength of the antenna. This is a lot more complex set of interactions than is worth going into here but hopefully it will suffice to say that in erecting various forms of antennas over the years, we have found that virtually any material in close proximity to an antenna has an effect.
You will not find any measurable temperature change.
k1vsk is offline
