SailNet Community - View Single Post - SSB Backstay antenna
post #17 of Old 01-27-2010
hellosailor
Zanshin, I'm not aware of any numbers for longwire antennas, but in general IIRC as the antenna "tubing" gets thicker, the antenna can work a wider frequency range with lower SWR.
I'm probably getting something not-quite-right with that description, but for conventional antennas thicker tubing has definite advantages, and the same physics behind it would tend to indicate a thicker wire for wire antennas might also have some real benefit. (Aside from being thick enough to carry power without heat damage.)
Something you might want to check into.
hellosailor is offline
