SailNet Community - View Single Post - Stowing Portable Gasoline Generator
post #2 of Old 01-28-2010
k1vsk
Most of us already stow gas for the dinghy outboard so this isn't really a safety issue, as some might suggest, as long as you follow the same common sense rules. Drain the tank (not easy on a Honda 2000), run the carb dry, ventilate the tank (easier than it sounds and takes only a minute as verified by my combustion meter) and store it in a locker similar to that designed for propane to ventilate externally. Your cataline 35 might not have a proper locker and need to be modified.
I and many of our cruising friends do as described above without concern - it's more the folks who don't or haven't tried who will tell you how dangerous this is.
k1vsk is offline
