SailNet Community - View Single Post - hull reinforcement with liner
post #2 of Old 01-29-2010
Jeff_H
Moderator
Jeff_H's Avatar
You do not say precisely what you have in mind but I assume that you are talking about adding internal framing. I do not know of an easy way to reinforce the hull with a hull liner other than to temporarily remove sections of the liner, build up the internal framing that you wish to add, and then glass the liner back in. You may also look at developing as sytem to reinstall the liner in a manner that allows the liner to be removable, or leave the liner out if you are going offshore. (I personally think that liners are dangerous on an offshore boat because they limit access to the hull should you be damaged underway.)
Jeff_H is online now
