SailNet Community - View Single Post - hull reinforcement with liner
post #8 of Old 01-29-2010
mitiempo
mitiempo's Avatar
If you just want to strengthen the panels a bit just hot glue some foam where you want the frame and glass over it with a couple of layers of biax and epoxy. Why are you reinforcing it? Does it flex more than you think it should or are you planning to go offshore? Like you say the problem is access with the liner in the way.
Brian
mitiempo is offline
