Old 01-31-2010
nickmerc's Avatar
nickmerc nickmerc is offline
nickmerc is on a distinguished road
If you are not worried about destroying the transducer, maybe try cutting it off flush to the inside of the hull then drilling it out with a large drill bit. Or you coulld use a rotozip or dremel to remove it. Just be sure to not remove part of the hull.
________
xLIttleWetPussy cam
