SailNet Community - View Single Post - How big are the holes in your mast step plate?
post #4 of Old 02-01-2010
sailingdog
If your mast step is aluminum, aluminum might work, but stainless steel would be far better, as it is far stronger and more fatigue resistant. However, if your mast foot/step are aluminum, it would be worthwhile to make a galvanic isolation layer to separate the two materials and help prevent corrosion problems.
Originally Posted by Northeaster View Post
Have you looked at the Garhauer mast plates? For these low prices, it is hardly worth making your own, if they will fit!
Garhauer Marine Hardware -657583
But, they are all rectangular. I just removed my mast step today, to do the same thing. Since my step, and the raised fiberglass area underneath it are both oval, I think I will have a machine shop make one. I think that a rectangular plate would overhang too much at the corners, and perhaps be a bit weak, as they would not be suppported as well.
Of coures it depends on loads, but for a typical cruising 30'er, anyone know how thick a plate should be done in stainless? What about aluminum, how thick?
sailingdog is offline
