SailNet Community - View Single Post - hoisting a large anchor
post #6 of Old 02-02-2010
SVPrairieRose
SVPrairieRose's Avatar
Originally Posted by jrd22 View Post
What SV was talking about was putting the anchor somewhere at low tide and then positioning a small boat on top of it as soon as the tide rises enough. You need a line run through something on the anchor so you have both ends to form a loop all the way around the hull of the boat. Tie it off tightly as soon as you can position the boat over the anchor and then as the tide rises, so will the anchor. Then just take it where you want it and cut the line, making sure you have your chain/line attached to the mooring ball or whatever you are using. It's best to use a non-stretch type of line. You obviously need a fairly large tide to do this, but you don't need a very big boat, a 12' aluminum row boat can carry a lot of weight.
Yup, that about sums it up. When I dropped my mooring (3000lbs give or take) we did this with a 30 foot crab boat. Worked like a charm. Just be sure that your moooring line/chain is ready to pay out fast and clear and nowhere near people. You will think that you have a moment or two to cut the line and get away, but as soon as your blade touches the line it will "explode". Good luck.
SVPrairieRose is offline
