The little Honda generators are pretty nice but you really can't do much except turn them on and use the AC power they make. As noted you can't charge batteries with them.
Your solar panel solutions are too small to do you much good. With a really efficient fridge you might be OK with 150 watts. That is about what it takes in hot climates. It's just hard getting the real estate on a smaller boat for adequate solar panels - but they do work great and are pretty much trouble free. A voltage regulator is a requirement for them too. You have a serious power problem you can't solve easily unless you don't use refrigeration and add some solar panels.
I would not consider 35 gallons of water "generous" but perhaps adequate. I would try to add another 20 if you could. You'll be hauling water several times per week.
Gasoline may be your biggest problem. A 50 HP outboard and the generator will take a fair amount of it. I too wonder about a 50 HP outboard. There is a reason?
You are facing perhaps the biggest problem - a boat large enough to hold all your stuff and tankage. It's the part you will be forced to deal with the most. It may be so full you can't go sailing. It would not be the first time that happened.
