SailNet Community - View Single Post - rebedding. old issue, particular Q:grinding/lexan
post #2 of Old 02-06-2010
sailingdog
I wouldn't use untempered glass on a boat. The stuff will be a serious hazard if it should break. Also, acrylic is much better for ports. Acrylic has better UV resistance and doesn't tend to foreshorten under impact. If the port is polycarbonate and it gets hit hard enough, it may flex and foreshorten enough to break the seal...leaving you with a leaky port.
sailingdog is offline
