Old 02-07-2010
eherlihy's Avatar
eherlihy eherlihy is offline
Will work to sail. :-)
eherlihy will become famous soon enough
Originally Posted by eherlihy View Post
Using a set of diodes, and a DPST switch, you can reverse the polarity going to a fixture with two bulbs, but this requires using the negative lead for one circuit as the positive lead for the other...
Ooops... I meant to say; "Using a set of diodes, and a DPDT switch..."
Here is a great schematic, thanks to Bebi Electronics: On the left, how this is done with filament bulbs, On the right, how this COULD be done IF the Lopolight fixture were designed (wired) to work with only 2 leads.
USCG Licensed OUPV Captain, ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
