SailNet Community - View Single Post - replacing our Universal 25XP
post #6 of Old 02-08-2010
OldColumbia
Hull Number 33
OldColumbia's Avatar
The problem changing engine manufacturers is the different dimensions, shaft length, prop size, and hose placement. etc. Our last repower evolved into relocating the hot water heater, new motor mounts, new shaft ( shorter), cutlass bearing ( the shaft was out anyway), relocating coolant tanks, and replacing control cables because of change in throttle location and transmission shift lever.
Each costing more in parts and labor. I'd keep it simple with a like kind engine.
OldColumbia is offline
