SailNet Community - View Single Post - Is a little Generator worth it?
Old 02-09-2010
sailingdog sailingdog is offline
I'd point out that the Tohatsu is only going to give you 7 amps when it is running full out... usually it will give less than 2-3 amps.
The small gasoline generators aren't really good for charging the batteries on a boat, since they have relatively low output. Using the AC side would make more sense, since you can run a fairly beefy AC battery charger with 1000 watts... one that puts out over 40 amps @ 14.4 VDC pretty easily.
If you have AGM batteries, then this might make sense, since you could get them back up to 80-85% of charge level relatively quickly. But, with wet cells, with their more limited current acceptance rates, charging them to the 80-85% level will take more time...
IMHO, you'd be better off, if you only use the boat on weekends or occasionally, rather than living aboard, to get a medium size solar panel to recharge the batteries. I've written a basic primer for solar power on boats which you can read here.
Originally Posted by akin_alan View Post
I have a Tohatsu 9.8 outboard on my 30' 1974 Grampian sloop that I bought a few months ago. Very much enjoying the boat. My understanding is that the outboard charges the battery with 7 amps DC power.
I read the specs on Yamaha and Honda Generators. They put out a whopping 1000 Watts AC power! Well AC is something that I don't use much on my boat. DC is what I need. They only generate 7-8 amps DC power. 8amps x 12 volts = 96 watts DC.... I think that ain't much. I got three 90 (+-) amp batteries. Does that mean I got to run this generator for nearly 30 hours just to charge the batteries?
