SailNet Community - View Single Post - CAL 25 cockpit not draining
post #2 of Old 02-10-2010
svHyLyte
Old as Dirt!
svHyLyte's Avatar
Most of the Cal 25, 27 and 29's I've seen have a drain at the aft end of the cockpit sole that discharges through the bottom center of the transom. It's fairly sizable and, on our old boat, would normally drain a cockpit filled to the level of the seats in 2-3 minutes. There is, however, a little collection basin adjacent to the drain-hole that can easily clog with debris--leaves and what have you--that will slow or prevent draining. This is especially so if a prior owner installed a "flapper valve" cover over the outside of the drain to prevent following seas from blowing water back into the cockpit.
FWIW...
svHyLyte is offline
