SailNet Community - View Single Post - CAL 25 cockpit not draining
post #5 of Old 02-10-2010
Faster
There should be valves at the hull...make sure they are open, then try rodding out the line with a stiff piece of wire if the run is straight enough. There is a possibility that the valves, if present, will not move - but are probably open and can be cleared.
Faster is offline
