Island Time PC
uses the Bullet made by the same people that make the Nano Station.
The Bullet is designed to plug into a WIFI antenna. Ubiquiti makes both units.
I used to push the Radio Labs antenna, then came the Nano Station, No drivers to install and no cable length restricrions as with the Radio Labs RV wave.
The Bullet sells for about 58.00 and then you have to get an omni directional antenna. Depending on the gain the antenna could cost as little as 20.00 more than likely it will cost you about 75.00 for a high gain omni antenna.
So for around 125 150 boat bucks you could have a good wifi capable unit.
Fair Winds
Dave
