SailNet Community - View Single Post - CAL 25 cockpit not draining
post #6 of Old 02-10-2010 Thread Starter
sailguy40
sailguy40's Avatar
I don't think it has valves, only drains with hoses attached. The only thing I notice is the 2 drain holes on the floor of the cockpit that lead to those 2 hoses in the inside which are just under the opening to the cabin. Both of the hoses are attached with hose clamps on each end. I am nearly sure they go straight down to the bottom of the hull into the water. It has to be just debris clogging them up. I am going to try to rod it out, should be all thats necessary and its what I first thought about doing. Thanks for the help!
sailguy40 is offline
