SailNet Community - View Single Post - CAL 25 cockpit not draining
post #8 of Old 02-11-2010
svHyLyte
Old as Dirt!
svHyLyte's Avatar
Humm... You must have a newer Cal. In any case, Skylark is correct. Any through-hull below the waterline should have a seacock to allow it to be closed when/if necessary. In re: cleaning, you may find an investment in a plumber's snake (or the rental of one) worth the investment. Depending upon your location, you may also find that critters have set up house-keeping in your drain-lines and need be removed to keep the lines clear.
Good luck!
svHyLyte is offline
