SailNet Community - View Single Post - Windless cable size, cable manufacture and battery type?
post #10 of Old 02-12-2010
sailingdog
They're vastly undersizing the wiring. For an 85 amp load, at 12 VDC, with a 25' run (one direction) 4 AWG wire is going to result in a 9.04% voltage drop. This is really a bad idea.
1/0 wire over a run of 25' (50' total) with a load of 85 amps @ 12 VDC, will result in a 3.57% voltage drop... Ideally, you should be using 4/0 cable for this.
The voltage drop calculator I used is located HERE.
Originally Posted by SanDiegoChip View Post
Finally found the cable size in the windlass manual It is 4 AWG up to 50’ run.
sailingdog is offline
