SailNet Community - View Single Post - Windless cable size, cable manufacture and battery type?
post #22 of Old 02-18-2010
mitiempo
mitiempo's Avatar
This is the one I use but probably not worth it for the crimps most owners need as Genuinedealz charges only $1 labor per crimp. I see the point about aligning the lugs properly but if you lay the entire cable out and then connect the lugs to the windlass, solenoid, and batteries after it should work ok. A good crimper isn't inexpensive unfortunately and hard to justify for a few crimps. You may be able to rent a crimper locally however.
Brian
mitiempo is offline
