SailNet Community - View Single Post - Windless cable size, cable manufacture and battery type?
post #26 of Old 02-19-2010
sailingdog
There is a big difference between saying that all crimping tools are useless and that the inexpensive ones sold by Lowes/Home Depot/etc., are useless...
I use a non-ratcheting lug crimping tool that works quite well. I've seen the results of a decent lug crimping tool and would argue that even 4/0 AWG wire lugs can be successfully crimped with regularity—USING THE PROPER TOOLS.
Originally Posted by svHyLyte View Post
The information was given to me by one of our neighbors who, with 40+ years in the industry, is the chief electrical engineer for one of the largest electrical wire and equipment distributors in the US. His comment was in answer to my question as to which "crimper" I should use when I was installing my own windlass. Unless I was willing to spend several hundred dollars for a tool for which I would only have very limited use, he indicated that the less costly devices sold by Lowes, Home-Depot et al, simply made poor connections. By comparison, the "Swage-It" tool is inexpensive, has many applications, can be used with relative ease in the narrow and tight confines of a boat; and, by applying uniform compressive pressure to the throats of the lugs ensures that the material of the lugs "flows" in and around the stands of the copper wire providing the best connection--just as does a swaged fitting on rigging wire.
Frankly, I don't care one way or another, nor am I an expert on the subject. However, I did, in 2006, go through the process the OP is going through, and thought he might benefit by my experience. Or not.
FWIW...
sailingdog is offline
