SailNet Community - View Single Post - yanmar 2qm 20 will not start
post #2 of Old 02-21-2010
sailingdog
Did the engine work properly before you changed the fuel filter?
If so, considering that the only things a diesel engine need to run are fuel, air and cooling water... and that you've mucked with the fuel filter... it is most likely that you've got air in the fuel lines...
sailingdog is offline
