SailNet Community - View Single Post - yanmar 2qm 20 will not start
post #4 of Old 02-21-2010
sailingdog
It could be bad fuel, but I think that if you bought from a reputable vendor, that is less likely than the lines not being bled properly or an air leak in the lines. If you replaced the fuel filter/water separator, did you double check the o-ring on the filter??
sailingdog is offline
