SailNet Community - View Single Post - yanmar 2qm 20 will not start
post #7 of Old 02-21-2010
wwilson
Chesapeake Sailor
wwilson's Avatar
Hi Rik,
No, i'm not a diesel mechanic either. I did have a very good diesel mechanic teach me how to bleed the engine though.
There is no reason to be anxious about loosening the injector (at the cylinder) no harm will be done in any case. I did not mean detach - only loosen a turn or two. The engine's cranking power and the fuel pump's effectiveness are just a whole lot more effective than the little "finger pumps" normally used. And, if the air is in the portion of the fuel line between the finger pump (near the secondary filter) and the injector, the pump has a very hard time expelling it.
Wayne
wwilson is offline
