SailNet Community - View Single Post - Any recommendations on a AGM starter battery for a 4 -108 Perkins?
post #2 of Old 02-22-2010
JohnRPollard
Moderator
JohnRPollard's Avatar
Chip,
As wwilson says, some more info would be helpful.
For instance, are you replacing an existing starting battery, or are you in the process of adding a dedicated starting battery that you did not previously have?
What size/type batteries do you currently have?
what kind of battery switch do you currently have?
Etc?
That said, I would think the battery to which you linked should start that Perkins. But that is not the only variable in question. Compatibility with the rest of your system is important.
JohnRPollard is offline
