SailNet Community - View Single Post - Any recommendations on a AGM starter battery for a 4 -108 Perkins?
post #7 of Old 02-22-2010
JohnRPollard
Moderator
JohnRPollard's Avatar
Chip,
Wow. That is quite a project you've got going there. Lots of variables.
Generally speaking, an AGM will be okay on a wet-cell charging profile, but it will not be optimum. Which is not to say that it's okay to mix chemistries -- only that you might be okay with the current alternator/regulator when you switch to AGMs. The usual recommendation is to not mix battery chemistries.
But a project of this scope is well beyond my pay grade. Hopefully some of our electrical gurus will check in (e.g. btrayfors or Mainesail) and maybe offer up some advice/direction.
Anyway, sounds like you've i.d.-ed the starting battery.
Best of luck.
JohnRPollard is offline
