SailNet Community - View Single Post - Impeller replaced, but did I screw up?
post #2 of Old 02-24-2010
scottyt
the grease probably wont be a big deal, if everything was wet before, its just for start up lube.
as for the old vanes, you might want to pull the water lines and check them, they most likely got stuck at the line to block hose barbs. this is a good time to check all the hoses and clamps too.
scottyt is offline
