Old 02-24-2010
sailingdog sailingdog is offline
The lack of grease shouldn't be an issue as long as you've got water flowing into the system. The missing blades are likely stuck in the heat exchanger, and if you haven't taken that apart and cleaned it out, it is probably past due for it. It'll probably have bits of old zincs too. Speaking of zincs, have you replaced the zincs in the engine?
