SailNet Community - View Single Post - Announcing the Lean Green Machine Challenge
post #3 of Old 02-24-2010
sailingdog
I'd point out that the charging onboard electrical systems is also a bust... unless the system is a hybrid electric with some sort of fossil-fuel burning component... it will need a separate source to charge the system itself...
BTW, there's no way you'd get enough stored electricity to power the boat for 30 hours at cruising speed with a weight limit of 320 lbs. Just ain't gonna happen. Four T105 golf cart batteries are almost 300 lbs... and they only supply 450 amp-hours at 12 VDC.... or 225 @ 24 VDC, at a 20 hour discharge rate.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
