SailNet Community - View Single Post - Mounting solar panel on top of dodger hardware?
post #8 of Old 02-25-2010 Thread Starter
SanDiegoChip
SanDiegoChip's Avatar
Ok I went to the local marine store and they said this is another good way to go.
Because I do not plan on lifting them to the sun, just leaving them flat, it works best.
Mount the flat aluminum to the solar panel side to side, in my case bow to stern.
Mount the plastic clamps to the SS rail.
Mount the aluminum flat stock on the solar panel to the plastic clamps.
Of sourse there are four clam shell clamps and four ends just not all shown in picture.
Also I need to cut the tubing and aluminum to make two pieces.
Done.
No SS or aluminum touches each other.
Use the clam shell SS brackets and the SS ends for the SS 1” tubing to mount to SS tube and the top of dodger.
The order in doing the install may be different, let you know.
This weekend we will do the work.
SanDiegoChip is offline
