Old 02-25-2010
jrd22's Avatar
jrd22 jrd22 is offline
Courtney the Dancer
I prefer separate systems, although they require more direct management than just a simple crossover pipe between the two tanks (ultimate KISS). With a crossover pipe between the two tanks and all the supply/return lines from one tank only, the fuel can transfer to the leeward (low) side when the boat is heeled. This can cause fuel starvation while motor sailing if the fuel level is below half and all the fuel transfers to the "storage" tank. You can control this with valves on both sides of the crossover line (which should be installed at each tank so you can shut them off in the case of a leak in the crossover), but that requires management and access to areas that are generally difficult. If you simply run a redundant set of supply/return lines from the second tank to your dual racor, with a set of valves and "T's" you can select either tank and simply monitor levels in each. That is exactly the system that we have and have found it easy to manage, with the inherent safety of redundant systems.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
