SailNet Community - View Single Post - Cockpit drains
Thread: Cockpit drains
post #2 of Old 02-26-2010
sailingdog
If you're going to go with PVC pipe, I would go with schedule 80, rather than 40, since it is stronger...and I would recommend using epoxy resin to glass them in, rather than polyester or vinylester, due to the stronger secondary bonding characteristics. You might also want to glass around the entire pipe, all the way from the cockpit to the hull, however, if you do this, you can probably drop down to schedule 40 pipe.
If you decide to use hose, rather than PVC pipe, I would recommend putting in a seacock.
sailingdog is offline
