SailNet Community - View Single Post - yanmar 2qm 20 will not start
post #10 of Old 02-27-2010 Thread Starter
found the problem , on this engine the injector pump is built inside the engine all you see is 2 pipes comimg out though a housing on this housing behind the pipes is a bleed screw there was still air there once i bleed there engine started.
lordpoltimore is offline
