If the
exhaust mixing elbow or other parts of the
exhaust are clogged or restricted, the
exhaust gases can not escape the engine quickly enough. The
exhaust which builds up ends up preventing the engine from breathing properly since the exhaust doesn't end up leaving the cylinders the way it is supposed to, and the symptoms can be very similar to that of a clogged airfilter.
Basically, if you think of the engine as an animal... if it can't exhale properly, it can't inhale properly...and it can't run very well if that is the case.
Originally Posted by weststar
Sailingdog can you eplain what you mean by exhaust backpressue. Thanks
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
