It isn't ideal to have the two halves of the boat cored with different materials. However, it isn't a complete deal breaker IMHO. However, doing the work from the underside is going to take a lot longer and it is a lot harder to get it right. If you brace the layers properly, you can probably do a decent job of it. Using vacuum bagging would help, but that may be more complex than you want to get into.
One person I know who did this on two different boats said that doing it from the underside took about four-to-five times as long and that isn't counting the clean up, which was a lot more laborious as well. The repairs were about the same size IIRC.
If you do decide to do this, I would highly recommend using epoxy from
Progressive Epo_xy Polymers and Resins in NH and getting your fiberglass from
www.fiberglasssite.com. Remove everything from the cabin that you can and tape a heavy plastic tarp over the interior.
I also recommend using a full-face respirator mask with vapor and particulate filters rather than goggles and a half mask.
DO NOT USE THE DISPOSABLE MASKS—they are worthless. The full-face mask respirator will last a long time if you care for it properly and is far more comfortable than the half-mask and goggles.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
