While worth a shot, I'd point out that this will likely only dry out the innermost layers of the plywood and that the uppermost layers will still be damp and rotting... The brown water you've been seeing is generally a sign of the wood rotting.
Originally Posted by laHolland
That's a good idea, Rosa. I think I will try that first, and then reevaluate.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
