Old 03-04-2010
sailingdog sailingdog is offline
Originally Posted by davewild View Post
I would like to know if there is any way of assessing the condition of seacocks and through hull fittings? Of course safety is 1st priority but money doesn't grow on trees.
You need to clean off any corrosion and inspect the seacocks very closely to see if they've started to dezincify from galvanic corrosion. If they have any pinkish spots, they really should be replaced.
If they should need to be replaced, what brands, types and materials are recommended. I sail 90%+ of the time on a salt-water river and the rest on the ocean. If replaceing then quality( life-span, impact ressistance, etc) takes a priority over price. I have almost always found that better products work out cheapest over the long term.
I would recommend you read Maine Sail's excellent how to on this issue. It will answer most of your questions. It is located HERE. Per Maine Sail's post, I would also recommend using the flanged adapters. It makes replacing the seacock a lot simpler.
One last question. Do I need to earth them? I don't use shore power, apart from charging the battery with a double insulated charger hence no earth pin on the plug. I would think this means I wouldn't have earth leakage but I go through prop shaft anodes in about 6-8 months so I think a boat in my vicinity may have a problem. Is there an effective way of fixing this?
Thanks,
Dave.
No, grounding them isn't necessary.
