SailNet Community - View Single Post - Any pros cons on the Beta Marine engines please?
post #9 of Old 03-07-2010
redhead78
Red
beta
Erps, hey how are you. I picked up my engine last sat, I have 6 months to commission and then the warranty starts. Where are you located and what size motor do you need. My engine came with mounts, a control panel wired that you plug into a female plug on the engine. It has standard 60 amp alt, secondary fuel filter, built in oil change pump, a TMC60E trans, both trans and throttle have brackets so you can attach your cables to. My 35 hp eng is a 4 cyl, 2800 rpm, all engines below are 3 cyl. You can add extras, for instance, I added a 100 amp alt, high exhaust stainless, a waterproof panel,wf hrs, tach, start, glow and stop buttons, wf idiot lights and buzzers. You can upgrade to "c" panel, has all guages key start, tach, hrs. I opted for the custom mount package, they made the mounts east/west or side to side exactly 20 1/4'' on center. Front to back it not usually an issue with mounts. The dealer even showed me how to make a template with the mounts on, and a piece of 1"y 8' pipe sldes thru front to rear into the stern tube. Sorry so wordy, you can email me if you want.... Red
Red, 77 Jeanneau Gin Fizz 38
redhead78 is offline
