SailNet Community - View Single Post - How to make a 1/2 through hole a 1 1/2 through hole?
post #5 of Old 03-09-2010
Gene T
Gene T's Avatar
I would probably just drive a plug in the hole. Just something to hold the bit while you get it started. Wood or plastic will work OK. If you have time you could use thickened epoxy but that is overkill. Depends on what you have handy.Drill from both sides, just a little from the inside and finish from the outside.
Currently in Long Beach, CA
Gene T is offline
