SailNet Community - View Single Post - How to make a 1/2 through hole a 1 1/2 through hole?
post #7 of Old 03-09-2010
scottyt
buck eye is right, offest the hole so the guide bit has something to run in. or use the ply wood but dont put it behind, use a rubber cement to glue it to the out side then drill thru it. the rubber cement will peel away easily.
scottyt is offline
