SailNet Community - View Single Post - How to make a 1/2 through hole a 1 1/2 through hole?
post #10 of Old 03-09-2010
sailingdog
A couple of questions first—
What do you mean the through-hull is for waste discharge? Is it a bilge pump through-hull or a black water tank pumpout through-hull?
Where on the boat is it located—the transom, the hull topsides?
As for drilling the hole... filling it and then drilling the new hole is one way. Another is to drill a hole through a piece of 3/8" plywood and then attach the plywood to the hull and use it as a "guide" for the hole saw.
Running the holesaw in reverse will allow you to cut the gelcoat without chipping it much.
sailingdog is offline
