SailNet Community - View Single Post - Depth Gauge or Fish Finder...
post #2 of Old 03-12-2010
sailingdog
Why not just replace the depthsounder. It would help if you said what kind of boat you had in your signature or include it in the post. If the boat has a solid glass hull, you can install a new depthsounder without installing a new through-hull, since most modern depth transducers can easily shoot through a solid glass hull.
One way to do this installation is to set the transducer on a ziploc bag full of water. Move it around until you find a spot where it gives a good reading.
Mark the spot on the hull and then fiberglass in a 4" PVC schedule 80 clean out fitting to the hull there.
Cut a hole in the clean out fitting cap and mount the transducer in the cap. Fill the cleanout with mineral oil or non-toxic antifreeze.
Screw the cap into place.
sailingdog is offline
