SailNet Community - View Single Post - Electrolytic action on aluminum spars
post #2 of Old 03-12-2010
sailingdog
Using something like TefGel or LanoCote is probably better than using a silicone sealant. If the pieces are larger, say, like the base of a mounting plate or line clutch, you can use the thin plastic from the side of a translucent milk jug as a galvanic isolation washer, in conjunction with the LanoCote or TefGel.
sailingdog is offline
