SailNet Community - View Single Post - Reverse air not heating well
post #4 of Old 03-13-2010
SVAuspicious
Mermaid Hunter
SVAuspicious's Avatar
I think SecondWind is on the right track, depending on where you are. The most likely issue is that the water you are floating in is too cold - less than about 40F will result in no heat. The next most likely thing is growth in the heat exchanger and cooling water lines, requiring an acid wash. A refrigerant leak is possible but less likely than the others if the original installation was decent.
SVAuspicious is offline
